Oil on my side mount intercooler?
MysticMarine
179
Jun 20, 2011
Dallas, Texas
While changing transmission fluid I noticed there was a black oil leaking down the side of my SMI. Any thoughts on why?
It would indicate its time for a new turbo or turbo rebuild. Check your shaftplay. See if there is a bit of oil in the intake side of the turbo, then check your lower intercooler pipe for oil and grease.
Pop the hose off and see if there is a lot of grease and oily residue in it.
If there is, take the intercooler off and swish about a 1/4th cup of gasoline or paint thinner around in it and the dump it out. If there is a lot of black crap in it you have bad oil seals in the turbo.
It should just a couple of bolts. Probably 12 or 14mm heads. Did you pop the hose off it yet? Any residue inside the hose?
I've worked on my car the last two days in 100plus degree heat. I'll wait until this afternoon today.
If the seals are bad is the Turbo shot? With 22K the seals can already be bad?
If it isn't your turbo then it might be what happened to me. I found out my valve cover breather was spraying a little bitbof oil into my intake and getting into the turbo system causing it to build up in my fmic.
Where's the valve cover breather, I looked and didn't see one?
Indication of an almost blown turbo....or oil from pcv valve. Check pcv before spending turbo money.
I have a small valve cover leak. Maybe that's where the oil is coming from. I just can't see a turbo going out at 22K.
Another tip for less than 50 bucks places like radiator house will clean your intercooler for you
They cleaned mine it came back like brand new
