Oil. Oie.
95talongirl
Supporting Member
1,876
177
Feb 9, 2008
On a Jet Plane, Illinois
TrboBLu decided that she really, really likes life up on jackstands. Either that or she has a thing against the Brad Penn green oil. Regardless, a leak developed from behind the timing cover. Fearing the worst, the cover was removed... but come to find out it's just the oil pan.
Still.. she decided to give the preverbal
:f-u:
Did some test-fit on the seat brackets for the Recaros. Wedge Engineering made the brackets. They drilled one of the holes wrong on the driver's side... so had to drill it out some since they did not want to do anything about it. Oh well.
Also finished wiring the headlights. Got some Halo's now. Woo!
Alas, a new list of things to do before getting back to correcting the base tune on her.
Such is life. Water under the bridge! :cool:
Also fitted the new aftermarket carpet with the center console. Old carpet was pretty gross.
time to get dirty.. You can fix that oil pan leak by the end of the weekend. I have done this on my own car without a gasket just plain old high temp rtv and a few good techniques givin here on tuners and I havn't seen a drop of oil in almost a year! let me know if you need help
Those are just some regular 'ol eGhey ones. They fit alright, but could be better.
Thanks! decided to work on more of the interior this weekend. Had to swap over steering columns and such.
