rogergoochman
- 86
- 0
- Jun 24, 2003
toledo,
Ohio
I just swapped in the motor I had built. here are the specs.
.20 mahle pistons
eagle rods
ARP main and head studs
Clevite main and rod bearings
SI 1mm oversized valves and valve springs
SI titatanium retainers
New water pump
New oil pump
New headgasket
Forward facing oil filter housing
Balance shaft eliminated
Etc Etc
I let it run for about 20 minutes on first start up drained the oil. Looked Fine. Drove to the gas station and back drained oil. Looked Fine. Motor now has 25 miles on it, I check the oil its milky white and kinda bubbly looking on the dipstick. The car hasnt seen over 3k rpm and hasnt seen over 50mph. I know if theres oil in the coolant itll be milkt and its more then likely a blown headgasket. Not sure what it means when your oil is milky? Need help I dont want to have to put a headgasket on a motor that has over 4k into.
.20 mahle pistons
eagle rods
New water pump
New oil pump
New headgasket
Etc Etc
