Nighthawk01
- 128
- 0
- Aug 27, 2003
now loosing 0 oil since the new valve cover.
Originally posted by TSi90Awd
Bro, an easy fix is jb-weld quick set. Take the valve cover off and use carb cleaner or some degreaser and clean the top of it(on the inside where the leak is). Flip it over and find the crack, but you have to look very carefully because it doesn't take much more than a hairline crack to cause a leak because of the pressure inside. When you find the leak just apply jbweld to the crack on the outside<------. Let it sit, preferrably in the sun to dry the best. Then put the cover in shade until it cools down( if you bolt it up warm it cracks easier). Then apply the cover back to the head. Remember only 2-3 lbs. of pressure. And there you have it, a quick fix.![]()
Pressure? What pressure?Originally posted by TSi90Awd
Originally posted by BUCK
Did you torque it evenly - over & over until they all pulled 2-3 ft lbs? It takes a little while with a new gasket - & you don't put RTV on all areas of a new gasket - just around the half moon & cam areas.
Originally posted by 95AWDGSX
I read a post before about an oil cap gasket for this problem instead of buying a new oem one. Can I get that gasket at any auto parts store? Correct me if I'm wrong.
Originally posted by 98RedGs
You don't HAVE to buy just the gasket, you can actually pickup a cap for about the same price+hassle of putting on the gasket itself. But call your local mitsu or parts store and tell em the gasket. They can hook yah up.
