Oil filter bracket bolt sizes
brandonzero0
376
Sep 1, 2005
Detroit, Michigan
Can any One help me, I need to know the sizes of the boltsthst go through the Oil filter bracket, front case, and then thread into the block. I really just need to know the length of each of them.
To add to the above post, there are 5 bolts referenced in the link. Only four of them mount the oil filter housing. Since I assume we are referring to your '95 TSI, these measurements are for a 7-bolt engine. From left to right as referenced in the picture:
1) M8 x 1.25mm pitch x 65mm long
2) Not an OFH mounting bolt
3) M8 x 1.25mm pitch x 75mm long
4) M8 x 1.25mm pitch x 65mm long
5) M8 x 1.25mm pitch x 40mm long (farthest to the right, bolt not pictured individually but is indicated by 5th red arrow)
