Oil catchcan can ?'s
D Loco
57
Jan 29, 2012
Noble, Oklahoma
So if i want oil to quit spraying on my injectors I'm guessing this is what i need. questions are 1 do i need 2? was looking at setup diagrams and it showed 2. Can i use just 1? Should I use 1 with or without a filter on the top? (oil catchcan)
You can use one can with both the PCV and the breather run to on inlet. make it a sealed can that has a vacuum source. Good place for the vacuum source is the intake pipe as it will continue to draw out the gases during boost.
I personally run one can with both valve cover lines run to it and no PCV valve. Then rather than a breather I have another line run off the top of the catch can into the intake pipe vacuum port pre-turbo. So yes, you can run one can as long as it has 2 fittings and either a 3rd breather fitting (not my recommendation) or one vacuum fitting run PRETURBO (my recommendation).
Edit: I'm too slow. Beat to it.
Yes. I run my PCV and my breather to a "T" and the run the one hose to the inlet on the can, I then run the other fitting on the can to my intake pipe which I installed a fitting on.
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
