OEM Trans Part Numbers
nikkeebabee
253
Jul 21, 2004
Rochester, New York
Guys,
I can't seem to find part number for the following...
2g AWD 7 Bolt Flex plate
2g AWD 7 Bolt Pilot Bushing
2g AWD 7 Bolt Flex Plate Crank Bolts
2g AWD 7 Bolt Convertor Bolts
I know someone should have these numbers. I just can't seem to find them anywhere...
Hopefully the screen shots aren't too blurry.
Yes but if you look in JNZ, it says that the first part number has been superceded by the second one.
It's $45.43 from them.
Would one of you guys know where I could find some sensors for a jdm awd auto trans? Just finished a swap and everything is running good with the jdm sensors and harness but the transmission sensors don't match up with the harness??? Any suggestions? Thanks.
