trans issues!
Mike Marnik
349
6
Mar 5, 2004
Omaha, Nebraska
Ive been messing around with this automatic transmission all weekend. About 2 weeks ago the TCU ate the dust and is completly shot. So a friend of mine let me borrow a tcu and it did screwy things; shiftpoints were way off and it would randomly downshift then upshift and it shifted very hard. so i opend it up and it looked to have some cap damage starting. So I borrowed a manual shiftbox from him also, made by foreignmuscle.com. i installed it it worked great then i tucked it up under the dash where the tcu was, and started her up and no dice back in limp mode. So today I finally got a new tcu in (used in great shape). It works but now it wont start out in 1st i have to manually shift it into 1st and after that it wont shift into 2nd by moving the shifter i have to go to neutral first then put it back in drive. In drive it will start out in 2nd and shift to 3rd but as far as i could tell wouldnt shift into over drive but i never got above 45mph. It is also downshifting quite harshly. The transmission is completly stock and I havent done the bluewire mod. Im beat and usually dont get beat by cars but im also new to autos. It worked perfectly with the old tcu untill it died.
Check this fuse in the car..
(4A/T)
(BOITE AUTO)
did that a long time ago and several times after that. i wouldnt have been getting anything but third with that blown. and with the shift box it doesnt use that fuse. however i rewired in the shift box yesterday and it is working fine now. i dont know if in my exhaustion/fustration i looked over something or wasnt checking correctly to see if it was working right or not but not it works. However i think there may still be an issue with my tcu as its still no operating the trans correctly.
