OEM Oil Cooler Coolant Inlet Pipe
Dsm2Nv
183
7
Dec 27, 2007
toronto, ON, Canada
Hey guys i no this is a newbie question but where does this hose go ? does it go into the back ? when i removed the thermostat housing i completely forgot where they were going.
Does does this go into ?
is this bolt suppose to be blocked off?
If youre going to reconnect it to your throttle body and re-enable your FIAV then yes... It allows the car to idle properly when its cold. If you dont have issues with how it idles then you can leave it as is.
    • Sdcryan1
