2G Odd whinning noise from engine
Seeing that you have that "idle" problem my first guess as with all of these situations would be something to do with the TB sensors, but since you tested all of those, did you check the TB if there is a leak or if the screws are tight on the plate, your throttle cable isn't loose?
It *might* be related to your fuel pump. If the noise is that high pitch whine I hear, and maybe its not sending enough fuel to your engine and it starts to cut out when the rpm's dip. check fuel pressure.
Fuel pressure is at 43 psi
does anyone have any idea?
timing belt tension is good. i go up to 25 psi when performing a boost leak test and checks out.
What is your timing at? Also, how many psi did your system hold when performing a boost leak?
TDC on timing. 25psi for boost leak test.
What is TDC on timing? Your answer should be more like 5 to 10.
*Edit* Didn't see you have an SAFC, that may be your problem haha. Verify all the settings via the instruction manual. Arrow Upwards & to the right, 4 cylinder.
My guess is your base timing is off.
I'll check it tomarrow. all the settings seem to be good. Im not much of a pro on the safc 2
I don't think mine is adjustable
my base timing is at the "T'' and it goes to 2-3 dregrees while running. i dont know how to adjust my timing. I dont think its adjust able
What is wrong with my car?! any ideas anyone?????? I've checked everything that i can think of and i dont know whats is left to check...:mad:
Why is your oil pressure gauge disconnected? :hmm:
I would verify that your timing isn't off. Seems like it might be. What's the most recent maintenance you have done? :aha:
Do you have a logger of some kind? Post a log if you do. If you don't, buy one? :rolleyes:
Having to feather the throttle to keep the car from stalling sounds like a timing issue to me OR an airflow reading issue.
Take a video or pic of the engine bay.
It is difficult to help when we are suggesting things to check & you are saying everything is okay... if it was, your car wouldn't be having issues would it? :nono:
Your timing is adjustable. Via thru ecu tuning or other mechanical techniques (ie: cam gears, cas, timing belt off)
Items replaced
-I replaced the balanence shaft belt. ( it was chopped up bad ).
- Replaced spark plugs and wires
- Rebuilt turbo
- New battery
- New greddy Bov
- Fresh oil
- New coil packs
- MDP sensor
- Vacuum caps
I checked the timing again and it was at 5 deg. when it decided to run smooth. I do have to feather the gas to keep it running. What kind of logger would suggest? It didnt use to make the nosie while ideling before, but when i decided redline line it for about 30secs a couple of time to see if it may be mechanical. Starting to think a bearing? I have another video, I will get a picture posted on here about 630pm tomorrow. I had both my car and truck broken into last night as well me going to school and working full time. I apologize i was still in panic mode. I should of listed the things Ive check and have been more detailed.:ohdamn:
Things I've checked.
Upstream O2 sensor (Good)
CAS
adjusted TPS to .63
fuel pressure is at 43psi ( but when i give it gas it jumps to 50psi???)
No boost leaks
MDP sensor is good
Comb is good
altenator is good
power steering good
compresson is 150 across
spark plug gap good
removed all covers
SAFC II is set correctly.
Vacuum pressure seems to check out -20
Did you make sure that the balance shaft was in time? How did you manage to replace it without removing the timing belt? Finesse?
What are the spark plugs gaped at? What plugs & wires are you running?
Is the bov recirculated?
The balanence shaft gear was on the timing mark when I installed the belt. I did have to remove the timing belt in order to get to the balance shaft belt. I kept my cam gears in place with zip ties. If I remember correctly, my spark plug gap is set to 32 to 35 thousandth's. I'm running NKG spark plugs. Wires I can not remember off hand. The bov is recirulated.
I'm not familiar with 2g clusters but what lights are on besides the brake light? Looks like a CEL?
But if your timing is off your vacuum will be off as well, and with that off it will mess with the ability to set you SAFC correctly as well. So creating a chain of bad events all based off one thing.
Was there any carnage from the Balance Shaft being messed up like you said? Skipped timing or such? Miss aligned gears. If I remember right from the procedure in installing the Belt you have to time the oil pump or front balance shafts in time with the crank.
Was a leakdown check done to verify that your cylinders are sealing up?
Your CEL is on... what are the codes? Checking that should always be your first move when you think something is wrong.
Either I'm going deaf or my speakers suck because I don't hear it.
If you have the stock 2Gb CAS, no it isn't adjustable.
At idle, your ignition timing should be jumping around at anywhere from 5* BTDC to 15* BTDC. Since you have an SAFC and 550 injectors, your ignition timing should be even more advanced than that. Is your TB idle switch set properly?
Well, if it wasn't already... :p
CAS
How'd you check these?
adjusted TPS to .63
Well, then your FPR must be seeing about 7psi of positive boost when you do that.
No boost leaks
MDP sensor is good
Comb is good
Comb?
Did your DSM join hairclub?
Please enlighten me as to what you really meant.
alternator is good
power steering good
compression is 150 across
150 isn't horrible but a tad on the lower side for a 2G, how many miles on it?
spark plug gap good
removed all covers
It's not your problem but you should close that gap to 0.028", assuming you're running regular copper plugs.
check your power steering fluid, this same thing happened to my wifes Lincoln LS, and it happened to my eclipse last month. It started whining real bad put some power steering fluid in and was good to go on both occasions. If your good on the fluid your power steering pump its about ready to go on you. the bearing in the pulley is screwed. my best suggestion. let me know how that goes.
Also does the noise seem to go away or get a little quieter while your driving? If so ill bet money is your PS pump
What about your Balance shafts themselves? You might have a bearing issue with one of them. You could remove the front balance shaft belt and re-check for the sound )just temporary of course. You need a stethoscope so you can poke around the engine bay and narrow down the location of the sound.
A lifter going bad could also make this sound. Either way, it is definitely something related to engine RPM
