Null modem adapter/ Gender changer
big_d
718
7
Nov 29, 2005
Columbus, Indiana
Can someone please explain the difference between a null modem adapter and a gender changer. Are they the same thing? The reason I ask is that I'm going to start using my laptop for logging and am going to buy the Keyspan serial to usb adapter. I have a gender changer that will work fine between my logging cable and the Keyspan unit, but I'm wondering if I need a "null modem adapter". Thanks, big_d :talon:
I would say you'd need a gender changer as it's use is to connect two cables together.
In serial communications, there exists a type of adapter that is similar in appearance to a gender changer, and in fact may provide the function of changing the gender, but is not the same thing. This device is called a null modem. Despite the word modem appearing in the name, it is not a modem. Rather, it is a device with the appearance of a gender changer that imitates the presence of a modem.
A normal gender changer simply changes the gender without rerouting any pins. Therefore, pin 1 connects to pin 1 on the other side, pin 2 connects to 2, pin 3 connects to 3, and so forth.
A null modem reroutes wiring so that two serial devices may connect directly to one another without any communications hardware (see RS-232). For example, a null modem crosses pins 2 and 3, so that pin 2 on one side is connected to pin 3 on the other. This causes the "transmit" from each side to be routed into the "receive" side of the other, similar to how a crossover cable is used in Ethernet to connect two devices directly without a hub or switch. Two to three other pairs are similarly crossed in a null modem.
A null modem may also act as a gender changer if it has the same gender connector on both sides. Other null modems have a different gender on each side. It is important to recognize that a null modem used in place of a gender changer (or a gender changer used in place of a null modem) will result in an inoperable connection, even if the connectors physically fit.
Taken from here:
Gender changer - Wikipedia, the free encyclopedia
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
