Nt slave cylinder on turbo car
dsmsucks
660
4
May 14, 2005
Rochester, New York
Well as some might know I have been having problems getting into any gears. I found out that I have a nt slave cylinder. So I checked and theres a difference between the turbo, nt, fwd and awd. The nt has a shorter rod than the turbo. Could this be a reason why im not getting into gears? Remember I bleed the piss out of the system, new fork and ball(shim twice), and master cylinder
thanks in advance
update
A friend just changed his slave cylinder of his vr4. Turns out the rod I have is shorter than his. He gave me his old rod and I will be installing it today. So you guys that are having trouble getting into any of the gears after doing everything correct, make sure you dont have a nt slave cylinder:)
    • Sdcryan1
