GSLENK
- 1,416
- 56
- May 25, 2011
DC,
Maryland
Recently my car started doing something absolutely annoying to say the least.
It stalls. It is not from boost leak, venting bov etc...
You can skip the description between the asterics if you want, its long...
This doesn't happen all the time, but it has occurred almost at least once a day for about 1-2 weeks now. And is very irritating.
The first sign of trouble was when I started a 2nd gear pull (for logging). I built full boost 20 psi. and then at around 4500 or 5000rpm, at WOT my BOV went off very quickly, the car lurched and then continued. No knock, on the dash or in the log. Immediately built boost again and did fine. Lost full pressure. THe log revealed I did go into vacuum somehow.
This didn't feel like spark blow-out since I have been tuning slowly and the last time spark blowout happened was on autozone recommended oem style plugs. I have since switched to NGK BR7es (non-protruded), and change them at least every 12 months or so. Also I recently 7 months did NGK blue plug wires.
Soon after, maybe the next day or two something else started happening. Now it occurs just about every other time I drive the car. The car will stall in deceleration in gear, or under low rpm high load/gear example, 5th gear at 1500, anything that causes the motor to shake. This wont always induce a stall but it appears to be the most frequent.
Then one day I took the car out, and it stalled 100 ft from my house and wouldn't start. I had ECMlink on and running so I checked a few things, Car builds fuel pressure just fine (turned on fuel pump, checked the AFPR gauge, pressure was fine)
My battery voltage is fine. Car will crank for days. But the cranks sounded different than a dry crank. I could hear the exhaust puff with it, like it was about start. but no start at all as soon as I release the starter, it stops. No sputtering at all. Just stops.
I popped the hood, played with the TPS connector, the CAS connector, and the Ingnition transistor connector. All were on there although the CAS ant TPS are missing the wire clip parts. They have been this way forever and never caused an issue. My ECU is currently hanging out in the passenger footwell since I was doing some wire splicing and was too lazy to put it back just yet. I checked its plugs and they were tight. Tried to start, no good.
I then pushed the car across the street so I could further investigate. I then tried to start it just for kicks, it fired right up like nothing happened drove it around the block just fine. Drove it for 30 miles just fine. Did some pulls near a friends house just fine, drove home.
Next I drive to classes and it stalls in 1st gear while I'm lingering in low rpm 1st gear in parking lot traffic trying to avoid using the clutch (laziness) I start to roll on, then roll off then it stalls. I try to start while in motion, no go. I pull over with my momentum, wait and try 2 more times. 3rd time is a charm and I park my car. I pop the hood and touch only the TPS and CAS plugs since I suspect its the CAS (though with only minimal knowledge only knowing that it has to work to start the car...). I close it all up (didnt try starting) and go to class. I come back 9 hours later, gets me home just fine.
Sometimes I get the decel or low rpm stall, almost daily now. I don't usually get the no start situation.
I first thought plugs, but the car runs fine otherwise. My WBo2 is a year old if that. my plugs are a year old.
Are there any connections to the engine (electrical) that are absolutely essential to operation besides the CAS causing the car not to start?
I haven't done much recently. The last thing I did was drop the firewall wiring harness down a bit, to begin my wire tuck project in the future. nothing was cut or resoldered.
Any ideas are greatly appreciated.
I dont think a faulty bov would hold boost, or show vacuum Think about it.
