not your typical 3 dash light problem
jay-d
175
Aug 11, 2002
Toronto,
So driving home one day at night my coolant, battery and parking brake light come on, so I immediately assume its my alternator since this has happened to me once before. I got a 90 amp bosch alternator and installed it, started the car and no lights, problem free.
Later that day I went out and they came on, very very dim, I had my radio playing, heat on and nothing seemed to cut out.
I left the car over night, started it the following day, again no lights but once car warmed up the lights came on again. I checked voltage at idle with no acc, and its 14.63, i turned on all acc, lights, wipers, rear defroster, heat, radio, checked voltage, it was at 13.75.
I believe my old alternator isn't bad, i find it odd that the lights only come on when the car warms up, I've tried cleaning all the connections.
The last major thing I did before this problem arose was i swapped the FIAV.
Any ideas?
It is most likley the alternator....I a very simialer problem not long ago on my 97 GSt.
The replacement alternator I had was fine for a while, but I think the start of its demise happened during a dyno session. I think I over cooked it. It was doing basicaly the same thing.....replaced it again....and it is fine
When mine was doing this, it turned out to be one of two things:
1) Loose battery terminal connections
2) The big grey plug that goes on the Alternator was not COMPLETELY plugged in.
Checked both of these and have never had a re-occurance of the problem :thumb:
