Not getting fuel (stumped)
ATRAX
Jan 5, 2006
Thornton, Colorado
Ok, my 97 2G isn't getting fuel, we replaced the fuel pump, and same problem. We took off both the lines to the rail to check. We threw in another ECU, tested the mpi and fuel pump fuse, and it still isn't getting fuel. We then tested the power going to the CAS, and there isn't any, but it's not the ECU, so what could it be?!
Thanks much,
Jim
you also have the crank angle sensor which you will have to pull the timing cover to check, but if all the parts you listed are good then hard to believe, try swapping a known good ecu, so you have spark but no fuel. is your pump turning on with the ignition?
We checked both ECU's and they don't have leaky caps, so doubtful they're both bad. When we did the jumper to check the fuel pump fuse, we could hear the pump turn on. So, def check the crank sensor next?
