Noob question about fuel
stillslow91
Jul 14, 2013
Pekin, Illinois
So my 90 gsx is running on e85 (was running when i bought the car) and im wanting to switch it to 93.
Im in the process of downloading Jackal to retune the car and im wondering how to go about switching from e85-93
Should i let the car run all the gas out, siphon the gas out, or..?
Also is it recommended to change the fuel pump when doing so?
Thanks ahead of time for answering my noobie question.:idontknow:
Just run the tank down till the gas light comes on and then fill it back up with 93.
A little Ethanol won't hurt anything, gasoline today is up to 15% Ethanol already.
You should have a plug in your gas tank to drain it out (at least I do). That's an option. You can always disconnect the return hose and get another section of hose and plug it onto the return side of the fuel rail and put that hose into a container and then turn your fuel pump on (not your car) and let the pump push all the fuel out into the container. .
Your fuel pump is fine. You might have a stainless steel filter if the previous owner was running e85 in it. You might have to go back to a paper filter for 93. I would maybe call STM or a good shop that might know more about that.
Why are you switching to 93? Do you not have a close e85 location?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
