ECMlink noob 1st log dsmlink v2.5. please take a look
j_biggz
287
3
Feb 6, 2011
Vancouver, Washington
I have two logs here from today. I have a idle log and a cruise log. Please take a look and let me know if I have it set good. I go lean under anything after 10 psi and cannot seem to get around it. I am not stock and my list of mods are as follows:
Bolt-on Modifications:
E316g, injen intake, VRS FMIC,Greddy I/C pipe, Greddy timing belt, Skunk2 cam gears, NGK wires, evo 8 MAF, Greddy type rs BOV, XS manual boost controller, 560cc injectors, evo 8 fuel pump re wired, N1 exhaust, Fluidyne Radiator, Fuel Lab afpr
Engine Management:
DSMLINK v2.5 w/ Gigaware usb adapter, Cobalt boost, Oil, and Egt, AEM UEGO
Engine Internals:
weisco pistons, Crower cams 272, Eagle rods, Evo 8 crank, arp hardware
Drivetrain Modifications:
ACT 2600, Street disk and ACT Streetlite flywheel
Suspension Modifications:
eibach springs, KYB AGX struts, crossed drilled and slotted rotors with EBC(green pads),
Ive been playing around with the evo 8 maf and the mafcomp tool. I am not compeltely sure I have the evo 8 maf since it sayes # 482. I believe the evo's are #399 so I have been trying different things with it but it seems like its lean at idle and drops off 18:1 in anything over 10 psi. Wastegate on my 16g is 16psi so that kind of sucks.
