please take a look at the 2g log
cuong1106
70
Oct 9, 2002
port arthur, Texas
hey guys i have a 97 gsx with 50 trim 3in dp external gate, 180lph rewired fuel pump, denso 660cc injectors with all the other supporting mods except for a afpr. im at 16psi right now and i have the safc settings as follows. the low settings are 1k -12, 2k-5, 3k -5, and the for 4k-7k i have it at -10. while the high settings are 1k-4k is -18 4.5k -5k is -25 and 6k-7k is at -10. please look at the following log and give me insights on it. i know the log isnt the best but thats hows my car is running as of now. i know that i need to lean out the 4-5k on the high side more. please give me feedback. the only fuel mods again are a 180lph 3kgt vr4 pump with denso 660cc injectors. are these settings suppose to be like this? thanks guys
rpm o2 timing tps stft ltft
3304 .95 28 19 0 -7
3380 .93 25 25 -7 -7
3500 .89 24 24 -14 -7
3608 .56 24 22 -14 -7
3720 .09 26 20 -13 -7
3812 .89 25 20 -14 -7
3908 .89 26 20 -14 -7
4004 .83 23 26 0 -7
4112 1.00 20 32 0 -7
4284 1.00 13 45 0 -7
4488 1.00 9 45 0 -7
4732 1.00 8 56 0 -7
5032 1.00 9 70 0 -7
5308 .97 9 94 0 -7
5620 .97 11 94 0 -7
5888 .97 12 94 0 -7
6160 .97 14 94 0 0
6420 .95 15 94 0 0
6664 .95 13 94 0 0
6880 .95 13 37 0 -7
thanks once again
cuong
Looks like you're knocking real bad up top. Richen it up some, and see what happens.
Yeah, it appears that you really start knocking around 6500. However, with that said, I would imagine that the car is actually pulling timing before that even though its still advancing. You need to do a pull at 100% TPS or WOT in 3rd gear from 3500 and up. My guess is the car is pulling timing for cooland and intake temps (that won't show up as knock, but it will reduce your timing by atleast 2). As for your 02 values, I don't like to rely on those....better to look at your timing curve and use them as secondary guidance.
my curve looks very similar but it's wierd because .95 seems plenty rich. I know you can't use the O2 values or rely on them, but if the car advances timing at .97 I don't see why it would pull it at .95. Try to richen it up from the 6k mark I guess and see what happens.
