non turbo tranny
Any 4g63 fwd trans will work doesn't matter if it is 6 or 7 bolt engine you just need the flywheel from the N/T engine but being a 1994 if it is the stock engine it has a 7 bolt flywheel so you will need a 7 bolt N/T flywheel. Make sure you cheak how many bolts hold the flywheel to the crank just to make sure, and the awd, fwd turbo , and fwd N/T all have different flywheels so make sure you get the right one.
