noisy belt??? helpp!!!
boost69
104
May 20, 2010
bristol, Pennsylvania
hey i just replaced my crank pulley and now i seem to have a noisy belt, sometimes the noise will go away then come back, and when its squealing i can smell the belt burning, the belt is tight so im confused :confused:
any imput???
i dont have the ac hooked up so its only two belts the one from the crank to alt and waterpump and the one from the waterpump to power steering and they are both tight
i will check that in the morning , but if it was rubbing the noise wouldnt go away
Ive had it where the belt melts the plastic and it quiets down but when the plastic cool's down and i start the car again it makes noise. Its just an idea....
could be a poss thanx ill check that out in the morrning , would that make a squeling??
