Noise! help!
Maybe we're wrong, but I had an aftermarket pump go bad in less than 10K miles. NPW, I think. I got a new one for free, put it on, then the car got totaled 1000 miles later. I was under the same car again later, at the junk-yard, and it was leaking again already. Mine sounded like a brake drum on a lathe when it was going bad. It had metal shavings all over it when I took it out. I'd assume it is the pump.
Get an OEM one. It's worth the loot.
To see if it's the water pump making that noise, just take off all of your external belts when the car is making the noise and run the engine without any of them.
Just DON"T LET IT OVERHEAT..:ohdamn:
You can run the engine for a short while, enough to hear if the noise went away without the W-pump and accesories running at the same time as the engine. Hope that helps!:thumb:
Get a long screw driver and put the tip of it on water pump, ps pump or alternator. Put your ear very close to the end of the handle and listen for the noise.
