No windshield wiper fluid hose
maxddr19
141
Mar 12, 2012
Martin, Tennessee
Ever since I bought my car I noticed that it didn't have any hoses running down form the little holes where the fluid is supposed to come out. I'm trying to buy some new hoses and fix it up again but I have no idea where to connect them to. Any help? Also, my headlights are almost pointing towards the ground. I have no idea how to fix them but they aren't level at all.
The windshield washer reservoir is in the trunk, under the spare tire. The line connects to one of the pumps.
There are adjustments on the backside of the headlights that can be turned with a Phillips head screwdriver. There should be level indicators built into your headlights on top in yellow. There are two adjustments available, one being vertical and the other being horizontal. I don't remember which is which.
I suggest you read your owner's manual.
Well holy crap. I hate spreading misinformation and I'm sorry for that. Never imagined mitsu would do that. What a stupid decision.
Relax, man. Was not trying to argue with you. For all i know that article is incorrect.
I think he was sincere in is apology.
The hose is just some vacuum line you should be able to pick up anywhere. You will most likely have to remove the reservoir to access the pump, then you just connect your hose and run it a foot or so longer than you need so that you don't yank anything when opening the hood. Make sure to keep away from moving parts and anything that gets hot.
FWIW, on my 97 GSX the nipple where that hose connects to is directly below the DSM sticker/placard about 5 inches. It's tough to see. It's also got this funky rubber boot over it
The DSM sticker is speak of is the one on firewall, passenger side
on my first dsm 98 rs the washer bottle was in the engine bay (no rear wiper) right next to the brake fluid resevoir, pump is located on the bottom of that, in my GST the bottle and motors are in the trunk underneath the spare tire.
