newdsmtnr96
- 250
- 1
- Apr 16, 2005
Des Moines,
Iowa
Ok i just recently bought a turbo gst 2g. I been fixing issues that the previous owner tried to rice the car out. Like the gauges there were aftermarket,Te aftermarket gauges were Glued to the stock gauges and does not work. But heres my question. I been searching all morning and could not find a answer. I check the fuse in the turning signal port from fuse box. I checked the balbs I even read where there is suppose to be a relay under the heater a/c. Found nothing there. The turning signals will not come on. the Cluster will also not come on and the rear wiper does not come on. I have looked over this car so many times trying to find out what the issue is. Does any one have any ideas? I could really use some help on this because i have spent about 3 hrs trying to find the issue. More info when lights are on the corner lamps are working perfectly and i do not have any hazards or rear defrost eather. I been googleing and searching and yeah kinda stressed out a little.
If any ideas i do appretiate the help
Thanks
Newdsmtnr96 from nt 420a-to-turbo 4g36t
Thanks
also i would rip out all the fuses one by one and check them on my nissan i actually had a blown audio fuse that said it was the last one on the top row on the cover of the fuse box turned out it was the middle of the fuse box ??? i dont know why it was mislabeled but check all of them anyway
the previous owner used glue to hold the gauges on thank you for rescuing that poor DSM from the ricer plauge im sure the cars way happier with you
