420A no start after rebuld
jhunfiyell
69
Dec 12, 2012
williamstown, New Jersey
replaced seals and head gasket and now my car wont start. it cranks, i see it wants to start but it doesnt. i even got my buddy to give me a jump, and still no start. also, i did an oil change and i noticed that there was oil coming out of my timing belt? then i realized that my rings from the cams wasnt in the right position, so i moved it over some to the grove of the head. but anyways, im not sure if thats the reason for the oil leak. my car wont start, whats my next approach?
Is your cas plug in? Compression has little to do with this. Cas unplug will cause motor to crank but not start. Double check timing see if it is on correct too.
Also check if fuel injectors are sitting correctly as tight. Leaking injectors also cause no start.
what is cas?
also, i redid my valves, wasnt sure if that would have changed my compression? see im a newb, i just give out information to increase the solution.
my battery is on right now as well, and my lights turn on after opening the doors and what not, headlights turn on, hazards and everything. if this info helps. Wasnt sure if it was a battery problem? can it also be fuses?
Cam/crank angle sensor. It should be right off the valve cover where cam shaft connect to. Recheck timing and injectors. Compression is easy. Youtube it. You need to rent or buy the tester tho
