jamel16
- 439
- 644
- Aug 6, 2004
Richmond,
Virginia
Hey guys, I have a problem that I am stumped on. First I noticed I had a real bad vacuumn leak right under the throttlebody area near the isc. I did the boost leak test with the soapy water to verify this. Well I removed my throttlebody replaced all gaskets, removed and cleaned the isc and reinstalled all the components. After that I did another boost leak test on the manifold side and noticed it held up to 30 psi.My problem is after I reconnected everything and triple checked my work, now the car will not start, I've checked fuel, spark and airflow and all seems well. I did replace the seals on my injectors too. Is it possible that I put the isc in wrong or when I was using the soapy water solution, it got on some electrical connections. Sorry for the long post, but I need help, too much blood ,sweat, and tears invested. Thanks in advance
