v8s_are_slow
- 2,824
- 280
- Sep 30, 2002
Panama City,
Florida
Okay, I just put my tranny back in today after doing a clutch job and tearing apart my tranny for inspection cause it was grinding bad in 2nd gear and was gonna replace the gearsets but everything looked good so decided against it. Upon startup, I had no reverse. I know I didn't miss anything in the tranny so not even thinking about pulling it right now. It shifted fine in 1st thru 5th. Just not reverse and won't even TRY and go in reverse. Car running or off, It's the same. Adjusted it at the pedal and still nothing. I'm thinking "maybe" my cables so wanna shift it by hand 1st and then do it with the cable to see what happens, but where is reverse if I'm shifting it at the tranny by hand? Just not sure which position it needs to be in. If I'm looking at it from the front of the car, does it need to go down and then left or right? Or in the up position and to the left or right? Thanks. This is a 98 GS-T btw, with Fidanza, Act 4 puck, and Spec pp if it matters.
Oh yeah, reverse switch was really tight on top of the tranny so loosened it up and then some just to be sure.
