no power to the computer??
need some help, 95 gs eclipse theres power going to the the computer but not comeing out of it, computer right, wrong i put a new one in it and the car still doesnt run, help me please :dsm:
You'll need to explain "power going to the computer but not coming out of it."
He's from Cali, sun must be getting to his head. But I'm sure he ment that he was under the impression of 1G n/t's coming with the 420A and reconizing his mistake
yes i did realize my mistake haha and no its not the sun its more like I'm at work and i shouldn't be on here so i did it really quick
as for OP i really don't know of anything else you could try sorry I'm stumped
I had the same exact problem with my 95 gs. I went through everything and I found out that on the 95's there was a recall for a reflash of the pcm. Mine was already reflashed and i still had the problem. I ended up replacing a bunch of stuff i didn't need but finally ended up buying a new mitsubishi pcm. It was like 800 bucks :( . Check the pins in the pcm to see if they are all getting and putting out power. otherwise you may be in the same boat i was in. I also have an extra pcm if your car is not a california emissions car. hopefully my experience can help you out some
