No Power to starter...
sakrafice
217
May 28, 2003
Sumpter, Michigan
Well first off heres the story...
Got this 95 talon tsi awd 5spd on a trade ... well long story short the kid lied his ass off to me and well im stuck with it and proceeded to fix his insane amount of #### ups. The car came with engine/trans/tcase outside of car and said "had all the stuff there to put it back together" well no there wasn't but thats not my problem... My problem is he had major electrical issues, i found old posts from him saying how he fried most of the harness and that the car wouldnt stay idle ect... so after finding that out i picked up a donor car (96 tsi awd 5spd) that i removed ALL of the wiring harness's and swapped them into my 95... that was a long process in it self.. well i finally dropped the engine in the car and wired in a few things and noticed i was missing the starter harness or whatever it is. the one i had was the chopped up one from the old harness and from not seeing what an original one looks like i have no effin clue so i wired that to the starter, the signal wire and it branches off to i think one of the boost solenoids on the firewall?
Any who from that it goes to the battery, and i grounded the starter from the trans (starterbolt) to the firewall were the battery ground is. Get in and turn the key, absolutely nothing, I can here the relay inside the car clicking, but thats it, fuel pump turning on when i turn key ect.. i jumped the starter with a jumpbox and the starter did engage (did this with the starter not bolted in) so i know or least think the starter is good (tried 3 other starters i had laying around.) Only thing i dont know is if its a 1g or 2g starter if that matters.
If anyone knows wtf im doing wrong or if im missing something on the harness for the starter please let me know, i read something about by passing the relay in case security or some bs is on but i see no security light on nor understood how to go about doing this. Thanks again.
Also on that starter wire harness does it plug into the harness like the 1g's or does it just go straight to the battery...:confused:
The big thick power wire goes straight to the battery on my 95 AWD, and I do know that starters are awd/fwd specific. As for the rest of the wiring, I feel bad for you because wiring sucks, but your best bet is going to be getting a Haynes manual and look at the diagrams.
Your other option would be to buy an entirely new engine harness out of a running parts car, which might be a good idea because you don't know what other issues that harness will have if it got fried a little, and if a couple wires are melted together that you can't see, they will keep getting worse and affecting more wires. Since the engine and tranny are out now, its the best time to do it.
You miss understood buddy. The wires "where" fried, so i bought a parts car that ran and took all the engine harness's out of that one and replaced them with mine, it was a pita to do but i figured in the end it would be worth it. The only wire that was missing was the starter cable wire, and the guy had battery in trunk with homemade wiring (amp cable wire) but i used the old wire he had which had the signal wire in it as well least i think thats what it is, clips on top of the solonoid above power wire on starter, and other end goes stright to the battery.
So:
Engine Harness
Interior Harness
Computer Harness
All have been replaced. With a 96 not 95, which a couple things were diffrent but not many.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
