Spyder no power to doors. HELP!
181161
109
39
Mar 19, 2011
El Paso, Texas
I have a 98 Spyder gst whose windows and electric doors do not work on either side. The switch has been tested and is working fine. I have tested all four of the window regulators manually and they are all working. I have checked the fuse and replaced the relay. My main issue is I have no power to the switches to lock or control the windows. need some help troubleshooting here.
sounds like you have some wire tracing to do. im assuming you had the door panels off and checked the wiring there? from there i would start tracing wherever they lead. could possibly be a bad connector in a harness plug somewhere as well. you can search for schematics on google or here as well. tons of info out there
When you hit the top down button to lower the convertible top, do the windows also lower?
I will try to post up the wiring diagrams a little later, if i have time
in the engine bay fuse/relay box,
-check fusible link 2 (yellow 60A)and 9 (green 40A)
-check fuse 11 (red 10A)
under dash fuse box,
check fuses 8,9.10,13
checks for windows and locks
Dumb question but this might assist-do your door speakers work (both sides)? Reason I ask is because the electrical connector itself that connects the door to the car may have come unplugged/loose (or corrosion).
Thanks this is some good info. ill get to work on it soon using most of this
don't have a stereo in the car right now so I honestly cant tell you.
Does everything else work? The ac fan, horn, headlights? I had something similar happen and it was the alternator components that were the issue.
AC was removed for alternator relocation, I haven't reconnected the horn after the quick release install but at the moment my headlights don't work. what do you mean the alternator components? as in the wiring and the fuse for it?
Hi does anyone know what the order in which the plug d-09 wires go. The old owner of my 94 Talon cut the plug and i bought new window motors. The pic y added is from the passenger side if anyone got a pic of the driver side i will be super grateful.
Is this what your needing?
1g door main switch (drivers side)
PIN1 -- Black/blue
PIN2 -- ??Green?? (i cant read it on the diagram, so i think its green but it may not be)
PIN3 -- Black
PIN4 -- Red/blue
PIN5 -- Blue
PIN6 -- Red
PIN1 -- Black/blue
PIN3 -- Black
PIN4 -- Red/blue
PIN5 -- Blue
PIN6 -- Red
Yes this is what i need thanks
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
