2G 97 GST no power..HELP
SEVEN2NiNE
Jan 26, 2013
Coatesville, Pennsylvania
So my check engine light came on the other day. I hooked up the scanner and it said misfire cylinder 3. No biggie, went and bout new plugs and wires, the old plugs were horrendous. Started it up with the new stuff and it ran like a champ, now this morning it seems as if its doing it AGAIN.
After 3 grand when boost hits I have absolutely no power and it seems to "skip" along. If I floor it, it just sputters along. I'm guessing that it is my ignition coil but I'm not sure. All help is very appreciate.
I forgot to clear the code once I put the new wires and plugs on. It's still on but ill just unhook my battery. It was way worse before I replaced that stuff. I was also wondering what a compressor surge will feel like? I have a greddy bov that might need adjustment.
Since I just purchased the car and haven't had it for a month the whole routine maintence thing is kind of irrelevant. After I bought it I did a oil change etc. it's was my coil pack.
