91_awd_talon
- 0
- Nov 12, 2009
Las Vegas,
Nevada
Ok here's the problem the car is not pushing out any heat through the vents when the heat is turned on I wanted to know what would cause this. The air that comes out is cold even when the car gets hot in the winter or while it's cold out like now. But in the summer when the car gets to the halfway mark if you turn the heat on it comes out hot like it should I don't understand this.
quick summary:
when cold out with the car warmed up no heat comes out not even if the car starts to overheat.
When hot out Heat comes out without fail...
Would the temp of the thermostat have anything to do with this?
quick summary:
