no heat
napkinthief
1,125
16
Apr 16, 2005
Cliffside park, New Jersey
well i had a problem with my coolant leaking from my lower coolant hose. replaced the hose with some new clamps and the coolant doesn't leak, but about 2 days later, i have no more heat. How can i check if my heater core went out or if its something else? the air blows out its just cold.
Well, if you are sure it's full then it's likely a flow or a blend door problem. Feel your heater hoses to see if they are hot. One should be hotter than the other as the hotter of the two is the flow toward the core. If they are both hot to the touch then I would look inside at the controls. Do your control knobs feel the same?
Check the hoses and post to let us know
Good Luck
Like Old Mitsu Tech said, you may have a clogged heater core, and need to flush it out. This happened to my brother's Trans Am, and we flushed it out with a hose, put new coolant in it, and viola! We had heat once again.
Good Luck
If I was new here I would swear you are hitting on me.
Lost the thread, Ill check it out tommorrow, the heater hoses should be warm after 10 minutes of idle, or after a long drive? I drive 40 miles to work at 50-90 MPH depending on traffic.
Its so cold outside that today halfway there, I stopped by a gas station, popped my hood and stood infront of my engine for 5 minutes pretending something was wrong to get warm. LOL
Ok I got some new coolant, and added it. The car was already warm, but I immediately noticed heat for almost 30 minutes. The heat again went away and now its just blowing air, not as cold as it was before I added. I didn't get to check it again when I got to work, but I will before I leave, and add more as neccessary. I think the problem with the coolant was I only put in one gallon and some water, but it was already a 50 50 mix. I got the prestone unmixed this time and put in about 1/4 gallon, then filled the rest from a gallon of water. Less tha 1/4 water added so I think im at around 55 45 mix right now.
Will do the heater core thing tommorrow.
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
  • For sale 4G63 FIC 1200cc Injectors
    FIC 1200cc Injectors $350 + shipping and paypal fees* injectors were cleaned 6/23/26You must...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
