No compression, cranks but no start
MintFlavored
Aug 9, 2004
Columbia, Maryland
So my brother's 1991 GSX Automatic lost power then died on the road. After getting it back to my house, I did the usual checks... it has spark, and fuel. The motor cranks normally, perhaps a bit fast, but it won't start.
I got my compression gauge out, and did a check. 0 on all 4 cylinders. Just to make sure I wasn't being a dumbass, I checked the compression on my motor, which came out to 145 or so on all 4. So I know how to use my gauge...
The weird thing is that the cam gears and timing belt are spinning normally, the cams are rotating freely, the valves are all moving up and down, and I don't hear any unusual noises.
Could the Headgasket have blown out enough to cause zero compression?
Could the valves be bent? What could have bent them and leave the timing belt and remainder of the valve train intact?
Any help will be greatly appreciated...
someone correct me if im wrong but with a blown HG i still think there should be some compression.
are you sure all the timing marks are still all set and that it didnt jump some teeth???
try a leak down test also and see where you get with that.
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 2g NEW OEM FWD Fuel Level Sending Unit
    2G NEW OEM FWD Fuel Level Sending Unit $85 + shipping & paypal fees* NOT the fuel pump hanger...
  • For sale 1g 1GA OEM Corner Lights
    1GA OEM Corner Lights $65 + shipping & paypal fees* all mounting tabs are intact * the...
  • Wanted WTB 1990 AWD manual Talon Transmission or shifter Forks
    I need a 1990 AWD 5 speed manual Transmission. The transmission has all the shifting forks...
    • 90rallytalon
  • For sale 1g 1g dashmat. Black.
    1g dashmat. Black. Overall good condition. Does have a tear where the dogear flap is on the...
