nitrous hard on engine
wannaspoolRS
112
Feb 24, 2005
Carmel, Indiana
now...nitro is obviously hard on the engine...my millage is 163K...and i want to squeeze a little more power outta her. will a 50wet shot of nitrous eat the shit outta my pistons or is there something else that i should get and what are the odds of pushing my engine to 200K...is that a rare thing to happen...
Compression Check is what determines the state of the engine ... You could have a car with 7500 miles and the engine is shot and have a car w. 163k miles and the engine is running perfectly fine- if you have a good result that then you should be able to push a small wet shot fine.
You will want to go w/ a few before you place nitrous into your engine. First of all you will want one range colder copper plugs (i used ngk). You will want to have your i/h/e done & you might want to consider an upgraded fuel pump. This should get you started - do some more research and You should be able to find all the answers to your questions.
Oh, and you might want to post in the correct section ;)
ide lay off the nitrous untill you have replaced some internal parts, 1 over spray can kill your motor, oh yea look into getting a really good and expensive headgasket :)
Do a compression test. If your over 180 across the board I'd say do a 35-45 dry shot. I'm not a huge fan of nitrous... seen to many engines blow from it. GSGoinFast has spray, and uses it ofter I hear. Get his opinion... cause he always has one :thumb: your the man Chris
He dosen't use it anymore - he's turbo now...I got it at the same time as him - i ran it w/ no problems....I stopped spraying now b/c i as well am going turbo...
Nitrous won't kill engine w/ one spray if it is good condition ... Stupid people kill it w/ one spray...If he has a good compression test - changes his plugs & wires, has some basic mods & upgrades his fuel pump I see no prob w/ running a WET shot - especially the zex kit as it has a built in device that only allows you to spray at WOT & stops if it sees something wrong.
im assuming you meant a "wet" kit. you really arent giving that bad of advice are you?
SnoopySLR said:
dry is safer than wet.... or so I've heard. I am by no means a nitrous expert, so sorry if I'm wrong
you've heard wrong.. dont post information on hearsay.. you are an ASE mechanic and are suggestion dry nitrous? :notgood:
ROFL it was nice, worked the way it should. if your engine is healthy then do it. but you will be very dissapointed with a 35 shot and even a 50 shot. i was dissapointed with a 55 shot... 75 shot was real nice tho, i just wanted the power all the time sooo boost it was.
