FirstTimeDSM
- 5
- Aug 18, 2018
Missoula,
Montana
Tried my ass off to find a wiring diagram for this but was only able to find to the rear o2 which is all accounted for and done correctly. At one point this was functioning.
My question is, does the yellow wire, which I believe is the analog signal out, go to pin 75(rear o2) on ecu with the brown going to it's own ground?
Second, if those are just analog out wires, what could be causing an issue of no display numbers/if it is just the display will v3ecmlink still see and account for signals coming from it? How do I test it under the assumption of no visual gauge?
