Newbie with Surge problem that led to timing belt issues (Long)
eagle93tsi
39
Jul 16, 2011
Cambridge, Massachusetts
Sorry if this is long, I am new to this forum and I want to let you know how I got to where I am and my questions. I have not yet found a similar situation or answers to my questions in other posts.
My car is a stock 1993 Eagle Talon TSI with 140,000 miles. I bought the car new and for much of its life it was regularly maintained by a great local family owned Eagle/Jeep dealer till Chrysler forced them out of business. Since then I have tried the replacement Chrysler dealer and a Mitsubishi/Chrysler dealer with less that desirable results. I was driving the car fairly regularly as my preferred vehicle, second car 99 Jeep Cherokee, until about 1 years ago.
My long saga started last winter. I was driving back from a friend’s 50 miles away on a very cold night, 5 deg F. The engine temperature never came up for the whole trip, Stuck thermostat was my conclusion. I let the car sit till spring as I have been busy at work and was trying to figure out where to get the work done. It was time for the timing belt and water pump to be done as well. I ended up taking it to a local gas station AAA recommended and recommended by several friends. They had worked on similar cars in the past so I had them do the work. They did replace both timing belts, tensioner and idler pulley.
The car ran fine for a 100 mile highway trip and an couple days of commuting. Then it began to surge horrendously, almost undrivable. At this point I decided that I wanted to get back into working on cars. When I bought the Talon I was doing some of my own work on my AMC Eagle wagon, engine rebuild, transmission and transfer case rebuild. I had many of the tools needed and the factory service manuals for the Talon, but not much time or knowledge about turbo control systems.
I started reading forums to understand what else I needed. I picked up a palm based logger from 1glink.com to see if there were any codes and what I could learn. I found “Terry's Talon Troubleshooting Tips #3 - Fast Idle (aka. Idle Surge)” and http://www.dsmtuners.com/forums/articles-engine-fuel/191137-how-fix-your-idle-surge-problem.html.
I started with the simple stuff. Changed the plugs and wires, no change. Then I did a compression check. 160 to 185 across the cylinders. Well above the minimum, but the spread is too wide, I am assuming it is carbon build up. Then I jumped to looking at the IAC as it was original and very common failure item in the forums, it had failed. I replaced it with some improvement. It was running just as rich and unstable with the throttle closed switch disconnected or not.
Next I bought a boost leak tester. There were leaks on the intercooler where the hoses attached, fixed these. The Injectors seals failed as well, replaced them and the PCV and fuel filter. The BISS was also leaking. Long ago one of the not so good dealers said I needed a new throttle body, but could not get one nor would repair mine. So I sent the throttle body off to throttlebodys.com for a rebuild. This should clear up any throttle shaft & BISS leaks and FIAV issues. I also cleaned up the EGR valve and the EGR diaphragm is good, no leaks. These all improved things a bit, but is was still not well. The car was not running anywhere near as rich, but still not not happy. I checked the compression again with the same results. I was assuming that the timing was OK as the compression was good. There is still a leak into the crankcase I have not figured out yet. I am hoping it is the PCV.
The rebuild had the BISS turned all the way in, so I went to adjust the BISS. This is where I started to get concerned, this was the first time I had tried to check the timing. I was assuming it OK as the compression was good. I think I was doing it correctly as the Palm logger was my Tachometer and should ground the needed pin in the diagnostic port and I grounded the single pin in the unused connector just behind the battery. The timing was way advanced 10 to 20 degrees moving around at least 5 degrees. I could not get the idle stable it would go up with opening the BISS. My conclusion was the base timing was not done correctly or the timing jumped. Time to check the timing belt.
I have now pulled all the covers to get to the timing belt and the timing marks do not line up. When I turn the engine over by hand at some points I have to work hard to keep it from wanting to turn backwards on its own, I do not know if this means anything. It confuses me. This is my first timing belt effort. Is this the miss timed balance shaft at work?
The cam timing marks are close, I think there may be 1 tooth too many between the gears. The upper line is just below the center timing marks and the lower one connects the outer timing marks.
The crank/balance is somewhat more troubling. I was very confused until I reread Timing Belt VFAQ (Timing Belt TSB - ENHANCED). The figure it has for the timing marks for a 1993 is very different from my FSM. The car is set close to the 1993 details in the post, but not quite right.
The oil pump sprocket appears to be off one tooth, red circle. The balance shaft seems to be off by 2 teeth, orange circle. The crank appears to be off two teeth. The engine spins fine by hand so I hope that nothing has collided.
In case it matters, I think it was 10 years ago the head was reworked, I forget the reason. About 2 years ago the ECU was replaced with a rebuilt one from Motoguys. Another poor experience with the Chrysler/Mitsubishi dealer where I had to get the parts to get the car fixed, they could not find them.
Sorry for the long post, but I wanted to provide all the details I could as I am still learning and not sure what detail may be the one to not leave out. I am not sure when I can get to work on the car again, but I want to start formulating my next set of actions.
I am interested in any advice or suggestions anyone may have on what I should consider doing next.
The timing belt is not set correctly, how bad is it? I am hoping that it is not so far off that damage could have been caused. This is my conclusion from the posts I have read so far and the last compression test with solid numbers. Nothing appears to be hitting when I spin it by hand.
My thoughts for going forward is to reuse the belts and reset their position. They have less than 20 hours on them. It looks like if I took off the main timing belt and turned the crank clock wise to the timing mark the balance shaft would be back on mark. If not I would loosen the tensioner and reset the timing.
For the main timing belt I plan to reset the position of each gear so that all of the timing marks are back in position. For the cam gears, twisting the one on the right counter clockwise and the one on the left clockwise. This will bring all of the marks in line. The oil pump needs to be turned clock wise to the timing mark. Then the timing belt can then be reinstalled following the instructions in the VFAQ. This should get the static timing back to where it should be.
With the cam shafts at the timing marks all the valves should all be closed so this would also be a good time to look for any other boost leaks, correct? I am hoping to solve the surge problem with all of this. Once the timing is correct then I can reset the BISS and hopefully be done. I want to get back to driving the Talon as it is more fun to drive and gets better gas mileage than my Jeep.
Alright. I'll tackle your timing issue here. What you should do is line up the crank indicator with the little arrow by turning the crank CLOCKWISE. Just eyeballing it from the pictures, it looks like your crank, balance shafts, and exhaust cam will line up to the correct position.
After lining it up, double check that the 3 mentioned above are in the correct alignment. You should then notice your intake cam is off centre by a tooth or 2. Try and measure it and refer to this post for a little more information. http://www.dsmtuners.com/forums/152268153-post2.html
You said it still starts, so thats a good sign. However, you'll want to get your timing sorted out, then continue to trouble shoot.
For future reference with this and any other issue, tackle one problem at a time then reevaluate. Welcome to the always 'exciting' world of DSMs
Thanks for the post link. I had not found these in my search.
In turning over the engine I had been focusing on the cam gears more than the crank. I hope to have a little time this weekend to work on it some more. I'll work to line up the crank and see where the rest of the marks sit.
I'll try the TDC screwdriver trick as well to see what it shows as well.
Most of the tools I need to readjust the timing belt just arrived in the mail (tension adjuster bolt and the tensioner pulley adjuster) I still need the drill bit or alien wrench for holding the tensioner and the gap measurements.
No need for this. The trigger plate is held in place by a small "tooth" if you will, so if the notch is lined up with the timing mark, you will be at TDC.
Also, I recommend going here >> Timing Belt VFAQ (Timing Belt TSB - ENHANCED) to help with the timing belt!
You may want to try a local forum and ask for someone to take a look at it for you locally. If something goes wrong here, it could mean your engine. Here's the short version.
- Remove timing belt
- Check balance belt alignment (if out of spec: reset)
- Compress and re-pin tensioner for main belt and re-install
- Align Crank at TDC
- Put Main Timing belt on starting with the cam gears alinging them properly (All marks straight across cam gear bolt heads
- Pull slack out of drive side of belt
- Set main belt tension
- Spin over by hand 6 times. All marks should line back up.
Not sure if you've found these (theres another link inside):
http://www.dsmtuners.com/forums/art...5-timing-belt-tensioning-tips-4g63-turbo.html
Here is an update:
Thanks crash89 and Auto RS T for the link recommendations. I had found these, but appreciate having good technical posts recommended. Searching does not always provide the good posts first.
I was going to work on the car this weekend, but life interrupted. I did do a few things.
When I line up the crank with its timing mark the balance shaft, oil gear and exhaust (left) all seem to be in the correct position.
Unfortunately the intake gear (right) appears to be advanced (clock wise) two teeth. Being nervous and not really wanting to take the head off right now, I picked up a digital inspection camera to look in the cylinders. The reliefs on the intake side (the larger ones) appear to be cleaner than the rest of the piston, but not gouged like I would expect with hard contact. There may have been contact, but not too hard. I hope.
One other little issue pointed out to me in a PM is that the balance shaft idler pulley is probably on backwards. The flange is away from the block, unlike the pictures in the timing belt VFAQ. Judging from the paint markings the shop put on it may have been this way when they took it apart. This pulley does not need to be removed to change the balance shaft belt, just loosened.
My first question is: Do I really need to reset the balance belt pulley? Is there a real risk leaving it alone? I have not checked the balance belt tension yet, if it needs adjustment then I’ll reset the pulley. If not I plan to leave it alone, at least short term.
As for the valves and the main timing belt, I am gambling the valves did not hit hard enough to be bent. I plan on just resetting the timing belt. Is there anything about the tensioner or the tensioner arm I should be looking for that could be contributing to my issues?
Hopefully I will get some time next weekend to work on the car and it will be a bit warmer. In the mean time I plan to study the recommended posts.
get the jay racing timming belt tool kit it will make your life alot easier. use cam locker to lock cams in place, crank at tdc, correct balance shaft timming it is off, tension and re pin hydrolic tensioner and re install, put on timming belt starting with the exhuast cam, zip tie the belt to the cam gears make shure to pull out the slack from the belt as you go to the intake cam gear, set oil pump gear one tooth b4 alignment mark put belt around pump gear and use a wrench to pull slack out of right side of the belt as you do that put it around the crack gear and when you get that have a friend put the belt around the tensioner pully and tension the pully. when that is all set remove the cam locker and zip ties and turn the motor over by hand a couple times to double check your marks. if all is good remove pin and put everything back together.
It might be worth it to check the balance belt since your already there it would suck to get it all back together and have your engine vibrate to death
The way pictured is the proper orientation for the balance shaft belt pulley....
Intake timing will not cause surge... your idle surge is likely your FIAV...
Send pics before pulling your timing setup apart, if you're off even a tooth you can feel it power-wise big time...
I finally got time to work on the car again. The first thing I did was to look over the installation of the timing belt again. I had missed before that the tensioner was sticking out 3/8 of an inch. The intake gear was still off by 2 teeth, the rest of the marks were fine. My conclusion was the belt needed to be readjusted as the tension was not done correctly by the shop I used. The balance belt was set properly and did not need to be reset or adjusted.
Following directions in the several posts on timing belt installation I was able to get it reset and set the tensioner properly. Buying the tools big binder clips, tensioner compression bolt and the Eccentric Pulley Preload tool made this much easier. Now all of the timing marks line up the way they are supposed to, even after 24 turns of the motor and waiting a half an hour for the tensioner to settle.
Once I started it up it did run better, but not quite right as I had not been able to set the BISS on the rebuilt throttle body. Following the BISS adjustment procedure I found the timing was advanced by 4 degrees. With the CAS readjusted I was able to get the BISS set to get the idle at 750. The car has not idled this low for years.
On the first drive to work the Engine Temperature sensor failed and threw a code, this was an annoyance, but an easy fix.
To get to this successful point I have replaced the spark plugs, wires, ISC, injector seals, cleaned the EGR, had the throttle body rebuilt by Throttlebody.com keeping the FIAV active, patched holes in the intercooler under the inlet and outlet hoses, reset the timing belt, adjusted the CAS, replaced the ECT. While I had the throttle body out it was a good time to change the fuel filter and the PCV with the easy access.
I have run the car for a few days now and all seems to be good. It is great to be driving it again.
Thanks all for your help!
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
