newbie.. qusetion on hks bov
weig0
Apr 20, 2006
new york, New York
i have a 1990 eclipse gsx, im tring 2 get a hks bov kit, will it fit in my car, ### all of them said its 4 1995-1999.
Yes it will fit a 1G. You need to have a flange welded on your upper intercooler pipe (if you have a metal one). If you are on a stock pipe, you can get the adapter below from www.dejonpowerhouse.com. They sell it for $49.
Click on DSM, scroll down to "All Mitsubishi" on the left side and then click on the 4th category which is "BOV-MISC-Tools".
thanks. so should i get the universal hks bov or should i get the 95-99 kit? i'm thinking the 95-99 kit would be better but i'll need to replace the adapter?
You don't need the 97-99 kit, just get the universal HKS blow off valve. If you don't have a GM MAF and MAFT, you'll need to get a recirculation adapter so you can reroute it back to the intake pipe. I do not recommend venting your BOV on the stock MAS.
ok.... wut else i need 2 get 2 install da hks bov? do i need another intercooler?
We all start somewhere i guess, but you should definetly read the link above, and please try to avoid the "da" style of speach it makes everyones job of reading your posts difficult.
good luck with your install, all the info you ever need is right up at the top of your page in the search button :thumb:
