pauleyman
DSM Wiseman
- 11,590
- 5,447
- Nov 19, 2011
oklahoma city,
Oklahoma
After 22 years of these cars on the street there is still so much misinformation out there I want to share these things with the newbies because we still see it too often.
I may interject some opinion here but cut me a little slack after wrenching on them for 20 years.
That being said here we go
1. There are no AWD or FWD turbo clutches. They are the same.
2. There are no 1g and 2g turbo clutches. They are all the same.
3. There are no 1g and 2g flywheels. They are 6 bolt or 7 bolt, awd or FWD. Do the math that makes 4 possibilities.
4. Model year and build date are not the same thing. If you have a car buildt in Feb 1994 it is not a 1994 car. It is a 1995 MODEL car with a 1994 BUILD date. This can play a very big role when looking for the proper part on ANY system in the car.
5. There is no 21 spline awd transmission. There are 22 spline and 23 spline and this refers to the output that goes to the tase. It has nothing to do with the input splines where the clutch goes. Those splines are all the same.
6. When doing a timing belt all marks must line up including the phase of the balance shafts if you still have them. Rotate the motor after the belt is on, line up the marks again and check the prottrusion of the tensioner. It is either in spec or it isn't. There is no other way to check it. It is stupid stupid stupid ridiculous that we see posts nearly every single day about a timing belt install going wrong. After this amount of time, the number of good writeups etc there is absolutely no reason for it. It doesn't matter what you do, the last item of checking the tensioner holds true no matter what. This is my personal number one pet peeve.
Others care to add to this list?
