Snacks
- 0
- Oct 8, 2012
Buckeye,
Arizona
Hey everyone. I just picked up a 99 GSX and I can't wait to make it road worthy . Here's what the guy listed on the add:
1999 Mitsubishi Eclipse GSX 21-24psi (365hp+) with stock internals. Set at 12-14psi (240-260hp) While replacing the timing belt, I also installed the Balance Shaft Eliminator Kit. (Have balance shafts for proof) Along with the vehicle, I will be giving all the tuning programs (Evoscan 2.6 and OpenECU) and the Tatrix along with cable. I will also give exclusive Roms and Definitions including Big Fuel Maps.
Modifications: 2 Step-Launch Control Anti-Lag 3'' Exhaust from Turbo Back. Title: Clean/Orginal
Mileage: Almost 89000 Ext. Color: Forest Green Int. Color: Black and Grey
Cons: Front and Back Bumper are OEM Gray Minor body damage to the rear that is barely noticeable. As of right now I am pretty sure the struts need to be replaced. Needs a CV-Shaft Boot Repair on driver side joint//No play
Tuning: Tactrix Open Port 2.0 OpenECU Evoscan 2.6 AEM Uego Wide-Band
Fuel: Walbro-255fp RC-660cc// Also have some 550's Apexi S-AFC Neo Can switch between 2 Fuel Maps Lo/Hi
Turbo: TDH05-EvoIII Super-16g G-Reddy Full FMIC G-Reddy Electronic Boost Controller// Also have Manual BC
Etc: Stage 3 Clutch from Clutch Masters// Also have another Stage 3 Clutch From Clutch Masters Cross drilled rotors in the front end brakes
New: Up-Stream o2 Sensor Fuel Filter Head Gasket Oil Pump Housing Gaskets Oil Pan Gasket Timing Belt OEM Carpet MoMo Italy Seats and Steering-wheel Door Panels Center Console
It needs new tires BAD, exhaust hangers, and a passenger side harness. I also have to get the AC working again cause the heat in AZ is retarded crazy.
