New turbo setup, no start
dabbdaddy
49
4
Mar 9, 2016
miami, Florida
Ok soo I f***ed up somewhere again and could really use some help
Swapped new turbo setup and added a afpr. After everything car turns on but runs like ass. Can't idle without throttle . Fouling 2 plugs almost every startup .
My afpr reads 43 when off (primed with ecmlink) when idle it's at 39ish . Isn't that too high for idle ?
I've done a BLT and fixed the ones I could find from not tightening couplers enough but same problem
Edit: went from 14b to small 16g running same tune, doubt the tune is the problem tho
Engine mods :
750 fic injectors
255 pump
Fuel lab afpr
Fp manifold, small16g , Megan o2housing.
Any input would be great thanks
That's with the vac line off No? Which is the same as priming with dsmlink with car off if I'm not mistaken . I can't set the pressure with the car on because it won' stay on at all unless I give it throttle
I just put a AFPR on my Auto car and a 255 pump. I ran 50 psi and just tonite turned it down to 44. It is something else not the pressure although playing with pressures will lead you in the direction if you cant see it on Link.
Could be your injector settings. I do MAFT tuning too and it will run like ass if the injector size isnt real close. Love Link!!:)
Vacuum leak. I just did Intercooler piping with a friend for my GST recently and it was doing the same thing at idle. Turned out it was the IAT flange for speed density that my friend and I didn’t plug. Imagine how bad it was sucking in air from nearly a 1” hole :ohdamn:
Im going to have to borrow one of my buddy's boost leak tester mine doesn' hold that much pressure .
But I've triple checked all my couplers and all hoses that I removed during turbo swap I changed out with silicone hoses and zip/clamped them all down
just rechecked all the lines and they are all tied and tight. going to have to wait for my buddy to bring me his boost leak tester to look for additional leaks . i uploaded a log of like 1min worth of me trying to get my car started maybe that can show my problem
Exhaust leak.
If you are running MAF and your showing lean and giviing it throttle and you know you have no boost leaks then I'd starting looking at the exhaust.
Have you made sure that your plug wires are in the right order? Have you verified that your getting spark on all four? Are you pulling the plugs to see which ones are fouled? are they on a common coil? Are you replacing the wet plugs? Sometimes the plugs are junk after they foul!
Yes I'm getting spark on all 4 . Everytime I foul I replace. I have another 8 pack of bpr6es to replace as I go along LOL
The plugs that keep fouling are #2 and #3
Correct firing order
And this thing ran fine before? have you done a compression test?
Man it was running fine , steady idle , nice afr all the way to redline. Turbo started going , had alot of shaft play so I got a new set up and now this.
I havnt been able to do another boost leak test but il get to it tomorrw to completely rule out a boost leak.
