new tires
j-jamrod
83
Nov 8, 2007
Baltimore, Maryland
should i run my new tires with the right pressure at the track or low pressure?
I drop my pressure a little so mine would hook when i was running kuhmos. The type of tires helps, my niitos did pretty good with no air pressure drop.
Is your tires a hard or soft compound.
Drop your air pressure, do a couple runs and then a different air pressure till you pick up on your times. Also keep a little light on the gas for first gear if you a using your gst
