96dsmftw
Supporting Member
- 293
- 247
- Jun 23, 2011
Richmond,
Kentucky
Hi all
My problem: Picked up some drilled/slotted rotors for the GSX and got them on. The drivers side caliper bracket, the part that bolts onto the back(knuckle?), it is rubbing the new rotor. We put everything on the same way it came off. Its pretty straight forward. We put washers in between the bracket and mounting surface to push the bracket out so it wouldnt rub. At one point around the circle it is about 1/16in away and the other side is like 1/4in. This is after the washers, before it has scuffed the rotor. I put on a pretty flat surface and tried to rock it to see if it was warped and definitely nothing noticeable. Tomorrow I will put the rotor on a level surface and try to check the parallelism between the rotor surface and the mounting surface. Also, the wheel doesn't wobble either just the rotor
Is there anything that sticks out to someone as to why this is happening?
Here is a video, you can kind of see it.
Thanks in advance
Thanks in advance
