Bent Caliper Bracket
spray004
Jun 22, 2012
Bham, Alabama
I dirt track race my 1G. I the past 4 or 5 races I've bent two right rear caliper brackets. I don't use my brakes while going into the corners and I havent been hit. Do 1G's have a problem with bending caliper brackets? They are bending enough that the RR caliper is starting to drag on the rotor.
Correction, the bracket didnt bend this time, the upper pin that the caliper pivots when you change the pads out bent...
If I'm reading this thread correctly, the claim is that putting stuff in the wrong hole can make you end up bent. I'm delighted to hear this, too, because the length of my index fingers and the direction of my hair-swirl had me a tad worried, happy marriage and two kids not-withstanding.
Not that there's anything wrong with that, of course.
