athlete3344
- 450
- 124
- May 1, 2010
Tampa,
Florida
Good afternoon,
I currently have a set of new Eagle rods (CRS5900MA3D) with King bearings (CR4481XP King XP Rod Bearings-6 Bolt-STD) and Im having a couple of issues:
- Torqueing rod bolts to 43 ft/lbs (marked Eagle 1.5 38 ARP 2000) with supplied ARP Ultra Torque lube is not meeting 0.0048" - 0.0055" spec. Im getting closer to 0.003-0.0035 at 43 ft/lbs.
- Rod oil clearances are still a little loose, ranging 0.0025 to 0.0034.
| mic set to 1.7780 | ||||
| 1 | 2 | 3 | 4 | |
| rod bore measurement | 0.0033 | 0.0038 | 0.0037 | 0.0037 |
| rod bore calc | 1.7747 | 1.7742 | 1.7743 | 1.7743 |
| rod journal | 1.7713 | 1.7713 | 1.7711 | 1.7712 |
| rod oil clearance | 0.0034 | 0.0029 | 0.0032 | 0.0031 |
| rod bolt torque | 43 | 43 | 43 | 43 |
| rod bolt #1 stretch | 0.0025 | 0.003 | 0.0035 | 0.0035 |
| rod bolt #2 stretch | 0.0025 | 0.003 | 0.003 | 0.0035 |
