7bolt oil clearances
schumy
79
Sep 5, 2011
westfield, Massachusetts
i have a 95 gsx with the 7 bolt 2ga (2ga is with cam angle sensor behind the cam gear I believe?) I am going to be doing a complete overhaul and would like to know what main and rod oil clearances they have gotten away with. the engine did have crankwalk so I was also wondering anybody knew how wide the stock thrust bearing holder was on the block side (I don't think i'm wording that right). I probably will get trolled but I don't believe in a perfect world, and these parts must be alittle more forgiving than everyone says.
If the block has any wear on the thrust surface it's trashed. I would still be Leary of using a crankwalked block, even if the bearing wasn't worn completely through into the block.
Well it did the most damage to the crank its scrap but there's luckily no big scratches along the side that I can feel with my finger nail I don't think it ever spun.
