kiggly
Supporting Vendor
- 326
- 223
- Feb 17, 2003
Ann Arbor,
Michigan
I've been fighting lots of problems this year and I still don't have some of them solved. The most recent problem is driveline-related. I will find the problem over the winter, but the result is the trans is sucking up a huge and unwarranted amount of power. I was able to get a new personal best time even with this problem though. The trans temp went up 100F during this pass (125F-225F) and the fluid is definitely smelling funky. This is a no-nitrous pass, FWD auto trans car, boost at 41psi.
60' 1.495
330' 4.096
1/8mi 6.213 @ 116.55mph
1000' 8.040
1/4mi 9.612 @ 141.96mph
Earlier this year I had a converter/trans combo that was putting power through correctly and I put down a 141mph run on only 27psi. By all accounts, I should be ~20mph faster at this boost, but there is a transmission problem keeping that from happening. Changes this year have included a new header and intake manifold to get better spoolup without sacrificing power. I'm also trying out some FP4 cams. I think I can probably go to something a little bigger, but these things have a super-hearty midrange which allows me to get the turbo spooled on the converter without nitrous and they're maintaining similar top-end to the huge cams I used to run in it. To jump the gun, since I know people will ask, this is with a Precision PT74GTS turbo (similar to a GT42) on a 2.3l with a 2g head, 28x10.5" slicks, and the race weight is about 2310lbs. There is a lot more in it learning the launch and getting the trans sorted. We will see next year just how much is still hiding.
I want to thank Precision Industries for helping me out with the converters, John@IPT for his help and advice, Wiseco for their help with pistons, TRE for their continuing support, and Forced Performance for letting me test out these camshafts. I'll do everybody some more justice next year.
Kevin
60' 1.495
330' 4.096
1000' 8.040
Kevin
. Congratulations for having one of the fastest streetable dsm's!
