New missfire
stealth13
136
Oct 10, 2008
calgary,
So, i did a new clutch install on my 96 tsi awd, the car was running perfectly before. After i started it, it gave me an engine code of a missfire and its still idleing poorly and you can hear it missfiring. What are some common things to check for this problem?
Also if anyone knows, after my clutch was put back together my car is making a kind of squeeling noise when turning left or going straight at very low speeds. Turning right its gone. Sounds like its coming out of the transfer case?
Figured out the second issue, anyone know what to check for a missfire?
Check all the electrical/vacuum connections you had to pull off to remove the transmission. If it wasn't doing it before then your spark plugs didn't all the sudden go bad, odds are you forgot to connect something.
:dsm:
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
