missfire?
Smell your exhaust and see if its rich??? But honestly, you need to be much more descriptive to get better answers... Also, check the condition and color of your spark plug... But I bet you either have a bad fuel pump, bad spark plugs (or incorrect gap for your boost, or incorrect plugs), or the famous bad spark plug wires (let her idle at night, look under the hood for the purple light show)
Low irregular idle, stuttering. Im pretty sure its fuel pump going bad. Im running lean. brand new NGK spark plugs gaped at .030 and brand new plug wires. and brand new fuel filiter
and no CEL
So, did you do a boost leak test?
Anything that deals with airflow (idle in your case) do a boost leak test.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
