New Maf and injector clips
white90gsx
674
Dec 21, 2006
Wilburton, Pennsylvania
I found a post about the injector clips(did not help me)..I torn the maf plug and injector clips off a mint non turbo 1g and want to use them...Mine look like crap so I want to solder new ends and heat shrink the wires so that's on less thing to go wrong on my car..Will I run into any wiring issues I know the colors don't match on the injector clips...
The NT MAF connector may be missing the wire for the MAF reset from the ECU. Only the turbo MAFs use it so your replacement connector may not have the pin.
The injector clips should work but you might want to change to a newer type of clip so you don't have to remove the wire lock to work on the injector.
MSD Ignition 2400 - MSD EFI Injector Connectors - summitracing.com
Yea true Im going to use that factory ones for now on the injectors...Thanks I won't use the maf clip.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
