new gauge cluster
dsm mad man
89
Dec 3, 2004
marriottsville, Maryland
im hooking up new gauges and i need to hook up the wiyers to a good ground and my head light switch but i CANT use my stock dimmer so where is my head light wiyer that i can splice into.
any help would be phat
90 talon tsi- hey also do i have a rev limiter?
If you are looking for a hot wire to power your gauge lights, you can splice into the wire that lights up the halo ring around your cigarette lighter.
Thats where I have my gauge lights hooked up to. I dont know why yours would be any different. Your gauge light wire may be shorted to ground.
If you use a fuse, find one that is only powered with the ignition switch, such as the radio fuse.
I'm not sure which fuse I wrapped the wire around, As I also have my autometer gauge lighting going off of fuses also. Just a 12v fuse, It may be the ciggerette lighter fuse, I cant remember, But when I turn the key on(Not starting the car) The gauges will be on.
If you dont know what a spade connector is, maybe you should take your car to a mechanic and let him work on it. A spade connector is just a flat bladed terminal used to connct wires together.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
